big 3 or capacitor to fix my problem?!
currently while listening to my system the bass "shorts out" on heavy bass songs or even when volume turned half way of max clean signal. im thinking its due to voltage drop??
my questions are:
1. will big 3 upgrade cause more stress on the stock battery/alternator from drawing more from it??
2. will a true good 1 farad cap help with my voltage for short burst when it needs it? (even though i know a cap is like adding a band aid)
3. or even upgrading to a better car battery?
i got 4 gauge wiring. just want a simple quick fix to be bumping loud again!
The big 3 is not a cure all.
I'd like more info as well, what do you mean it shorts out?
What IS* your voltage drop.....???
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Do the big 4 to start then upgrade to a the biggest agm battery underhood that will fit. (XS Power). We will be better to help you with knowing what equipment you our running. Where is your amp grounded to? How did you set your gains?
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
  • Who's Online   1 Member, 0 Anonymous, 1068 Guests (See full list)
