Slowwwwwly getting the door pods ready for some speakers.
Wrapped in fleece
D46BC1FF-17A5-4BFF-AA9C-BAC6A4DD89A6_zps
Getting ready for resin
303DA165-3A5E-4138-B3D4-2EF1C2407224_zps
Remembered gloves this time
0C830313-D0A6-4E38-8974-CA4B90CCADCF_zps
And ready to dry
E2B05D40-980C-40F6-8477-26828528E82F_zps
Took the picture in the shade, but moved them into the sunlight afterwards. Hopefully I'll have them finished by next weekend. Won't get anything done tomorrow, and the wife will be home soon so I doubt I will have anything more done today either.
In other news, I bought some rubber stoppers to put under the feet of my amps to help absorb some vibration and raise them up a bit for better cooling from underneath.
Things that need to get done:
-Design and build a new enclosure
-Design and build a new amp rack
-Purchase door speakers
-Run more wire and ground for rear battery
-Find a place to mount VM-1
If anyone follows this, sorry it's slow and not the greatest, but time and money are tight, I do what I can when I can.
Tuned in for this one brother
Team MaxRetribution
Si Vis Pacem Parabellum
Nice Ride brother
All dried up and ready for body filler and paint :)
AE405725-AB6F-49DC-8B27-1287A142FE02_zps
A little test fit. Has a little bit of a gap on the high side corner but I think once I actually mount it it'll be a snug fit.
69F8F71B-D853-49CF-A339-A1E775FA3DBF_zps
The drivers side 6.5 has the parking brake lever/pedal in the way though, any tips on bending it out of the way?
Are you venting into the doors ??
No, just a sealed pod. I want to see how it sounds first, and if needed I'll vent into the door. It will be SoundQubed's pro audio mids, with their component level tweeters. Do you think the mid will be better off vented into the doors?
i went through the same thing with my doors. don't forget to check and see if your glove box opens, mine wouldn't with the door closed. i never use it,but it just irked me. also mine sounded great sealed up, never tried to vent them,but i had different speakers.
Edited by moredbs
Good call on the glove box. I'll have to check it. Won't change anything, but it'll be good to know. Did you have to bend your parking brake pedal out of the way? If so, how did you do it?
I just ran into that glove box issue with mine. May have to put mine in the kicks.
Lookin good!
Lemme know if you need help with the enclosure design. If I have all the T/S parameters I can mess with it in bassboxpro. It takes FOREVER though so there is that..
Lookin good!
I've been playing around with the design with Torres and WinISD, but it's hard to find a medium between the two since they give different results. At least for a slot port. I need to try and do an aero design
  • Who's Online   0 Members, 0 Anonymous, 2425 Guests (See full list)
