if you are going to buy glue..
Liquid nails is trash
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
X2
And so is pl.
and I thought it was all about heavy duty construction liquid nails..... never fails me and fills gaps larger than the grand canyon
You got to cut straight, then you dont have to worry about filling gaps :D
You also dont need to silicon or caulk the interior edges when you have straight cuts and proper glue spreading.
I'm surprised it stuck to your table saw like that. I try to keep mine waxed up just so little drips are are easier to get off, but even an unwaxed top wouldn't have stuck that much I would have thought.
I've pretty much switched to TB3 exclusively now, pretty much for the same reasons as you, the greater open time really comes in handy.
I gave up on keeping it remotely clean. I was doing really good when I got it but no matter how many times I told people dont put drinks on it they always did.
Then one day a pizza box was sitting on my saw and it instantly rusted with in maybe 20minutes from the grease soaking through the box. Shocked the hell out of me!!
So every now and then I just sand it smooth to clean it up a little, but part of my problem is being limited on building surface so theres many times I lay a port that is clamped and drying on the saw so its out of my way and some glue runs off the wood, or worse glues itself to my saw over night lol
I always spread the glue evenly as possible.
I dont rely on the pressure of the clamps to do it for me.
You also got to use enough that it oozes out the seams.
Even when I get done spreading the glue around the boxes edges when applying the baffle if Im not fast enough I can feel it starting to set.
Thats why the open time is important. Tb3 also passes a higher waterproof standard as well but for what we use it for its useless, though some peoples trunks do leak. LOL
Finger spread the narrow edges
Larger panels I got these little green like bondo spreaders that cost $20 for 100 of them. At that price they are disposable once they get to glued up to use.
The old liquid nails was good for fixing furniture that the kids totaled. The new liquid nails is latex based and is more like bathtub caulk. Very disappointing on the dresser drawers. lol
Pioneer 80PRS
I cant remember, but its either PL or Liquid nails, but one of them never gets fully hard once cured.
Absolutely the worst to use for box building.
Liquid nails. I've heard nothing but bad things about that stuff. Pl premium (not pl 400 etc) gets pretty hard when cured. I have been using Pl for the last few builds but it is too unforgiving to me. you get it on anything it ain't coming off. Not to mention you can't stain it at all.
Also, when you glue a joint and it squeezes out in a bead, do you wipe it off before it cures? Just curious.
Being a Cabinet and Furniture maker not once have I wasted the money on Gorilla Glue. Titebond products have been around for years and are tested for there strength and holding abilities. Titebond here and I dont use fasteners in my projects. THE SUB BOX WITH NO SCREWS!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Titebond II/III here too, I use a enough to fill the connections and only bead some out when pressed on. You can see here it took most of the wood off from the top board with the exception of the spot the port didn't press on fully tight to the top.
liguidnails heavyduty construction gets hard like a rock when it cures, there are other versions of liquidnails that really suck and they stay soft... like the liquidnails tub and surround it still feels like my tub surround can be pulled right off the wall.... I would be willing to try other glues if I had a tablesaw or anything other than a jigsaw and a router for that matter.... ive been using screws and LN's for so long I love it
