What size fuse for alternator power wire
Why fuse the alt, unless you use two?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
yet his big 3 upgrade kits dont come stock with fuses?
LMFAO so true
:blush:
300 amp final answer lol. Really 150-300 amp you'd be ok. You want to use at least a 145 amp fuse because that's the most amps your alt is supposed to put out. And you don't want to go over 300 because you have 1/0 ofc. You fuse for the wire so don't go over what it's rated wich is about 300 amps for 1/0 ofc depending on length. If the wire is pinched then you want the fuse to blow instead of your wire catching fire, so if you fuse to high the fuse might not blow and it's as if you didn't fuse it. If you fuse to low then you might keep blowing fuses since the fuse won't be able to handle the current being pulled through it. Hope that helps.
It's an option. They don't come standard because most factory posts have them already. He has explicitly stated its a bad idea to leave it unfused.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
What size wire do you have for your big 3?
And yes, it is good practice to fuse the alternator charge wire.
If you fuse over 150A the fuse is pointless ON THE ALTERNATOR END for your application. If the alternator can only put out 145A how in the hell do you guys expect the fuse to do ANYTHING if it's 300A? IT CAN"T!!!! the alternator will just keep pumping out the magic fire pixies at maybe 160A (because of dead short) and shit is gonna fry until the driver realizes shit is frying and shuts the engine off or the rectifier cooks. The 300A fuse belongs at the BATTERY end but even then that is overkill because the wire is only being asked to carry 145A MAX so why fuse to the limit of the wire? All that is going to do is let more magic fire pixies out before the fuse pops.
  • Who's Online   0 Members, 0 Anonymous, 405 Guests (See full list)
