What size fuse for alternator power wire
ok that makes sense. im also looking at buying a crescendo s1500.1 for my subs, but i dont know which specs i need to look at to calculate the fuse that i would need. is it the volts x amperes = watts to figure out the fuse size?
Cresendo has two 1500 watt amps. One is ment for mids and the other is for subs, they are built different hope you chose the correct one.
*** this is the one for subs ***
http://www.down4soundshop.com/symphony-s1500-1-out-of-stock-eta-tbd/
*** this one is for mids ***
http://www.down4soundshop.com/symphony-s1500-1f-this-model-is-for-mid-range-not-subs/
Just in case you didnt know
yeah i was looking at the right one, thanks for the clarification though. What is the difference between the s1500.1 and the s1500.1f?
I dont know each specific differences but i do know the internal componets are different to handle its designed function. The s1500 is engineered for subwoofers and the s1500f for mid range drivers.
I told you to move the fucking....fuse?
So how about why NOT fuse the alternator wire?
potential voltage drop
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Which becomes a moot point the second your current draw exceeds your alternators output
so much misinformation.
based on the output of the alternator your gave, my guess is that its a gm unit. heck it can be any OEM unit. And I can tell you all OEM units are rated HOT and at lower rpm than most of the HO alt manufacturers. I'd bet my left nut that OEM 145A alt can do close to 160-180A. You go with a 150A fuse, it may eventually cause a significant resistance and eventually blow the fuse hopefully before it melts the holder due to the heat.
Either way, you fuse for the wire. because you dont want the wire transmitting too much current and melting causing a fire hazard. it should be placed as close to the battery as possible. 250A will be fine. but the fuse is for the wire, not for the device.
edit: an alternator will never put out a "spike" of amperage. the power isnt magically created under short circuit conditions. any power spike due to short would be coming from the battery.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
The answer is somewhere in these 5 pages. lol this is crazy. Do a search. This question has been asked before. I answered it before. I just can't bring myself to go through it again. Do a search for "Big 3 Question".
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 724 Guests (See full list)
