Lithium- Why isnt everyone convinced
Had my 20ah juicebox about a year with no problems.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
Lipo and lithium ion are the sketchy ones, would never use
Lifepo4 is what you need
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
looking at the ah rating for lithium doesnt mean anything...you cant compare ah in lithium to agm...that being said, the advantages to lithium far outweigh the price tag IF you are running 5k+...the price and weight of 3 standard agm 31 vs a single 40ah lithium, its an easy decision
another one to think about is the juicebox nimrod...rated at 1k per rod, 1.25" diameter x 28" long, they take up no space weigh about 8lb each..theyve been tested vs caps and up to 1k, the nimrod was the winner (as expected) and over 1k, the caps just took the cake (as expected, hence the 1k rating)...but thats just another lightweight/strong/efficient option next to the lithium...and they are easier to purchase, at $225 shipped a piece compared to $800 right away...you can build your bank piece by piece instead of saving and waiting...just food for your thought
personal build in progress
http://www.stevemeadedesigns.com/board/topic/188656-2013-kia-sorento-6-12-no-wall/
www.facebook.com/TurbulentDesigns
Juice boxes are Lifepo4....i say lipo because it's less words to type Lol
2000 Suburban 6 runs of 2/0
12 timpano audio mids,6 timpana audio tweets and 1 timpano compression horn per door
8 banks of blue Maxwells + 260ah of Yin Long LTOs
2 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
161.6@38hz DBdrag  sealed on the dash… 162.54 outlaw…161.14 Meca headrest
I'm seriously contemplating switching for the sake of space and weight savings but I too have been sort of sitting back and watching to see what happens as more and more of them get used over time. I make arrangements to budget for stuff I really want, but I don't have enough disposable income to be a trailblazer or risk taker so I try to wait until I'm very confident in something before I jump in and drop that kind of money.
These are engineered products. If Ah isnt the appropriate rating to compare to, then what do you recommend? There must be a comparable rating, since these are indeed batteries that store and release energy. I understand they do work at a different rate than AGM, but to say theres no comparable specification just simply cant be true.
IG @walledsonic
You have to realize lithium technology has really just hit a point where it's fairly stable and people can trust it. It's not exactly a docile platform and in large amounts can go up quick. It's had that tag associated with it for years. It's also now just getting to the point of marginally affordable. When I was doing my truck lithium was just becoming available. I got better reserve for less at the time. Now lithium tech is bypassing agm by leaps and bounds. It is the battery of the future and I'm convinced of that.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I can't exactly explain why the ah rating is what it is but you need only look at the curves to see the comparison
https://www.google.com/search?q=agm+discharge+curve&client=ms-android-verizon&prmd=isvn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi4ko3AtZ7PAhWKrB4KHVNQCVcQ_AUIBygB&biw=412&bih=652#imgrc=zYLnB_Mn-eYhRM%3A
You need to look at the area below the curve to see usable power. You can see how much more area the lithium batteries have. Conservatively 10x more from the worst to the best. So adjust the ratings on the batteries accordingly
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Lithium is rather old technology,
Graphene batteries will be the batteries of the future.
Oh nice , this is good information. Thats what I was missing!
On my last post I made the assumption that the Ah rating is at a constant voltage, when we all know voltage actually drops during discharge, at some rate that has to be accounted for over the discharge of the AGM. So to calculate watt-hours for an AGM, one would need to know the voltage drop per Ah to adjust the equation due to decreasing voltage. You are absolutely right about area under the curve. Basically, lithium holds a higher voltage for longer, so the voltage drop per Ah is less, resulting in more total watts for a particular Ah rating.
IG @walledsonic
  • Who's Online   0 Members, 0 Anonymous, 1647 Guests (See full list)
