kalilac619 Posted September 20, 2016 Report Posted September 20, 2016 I've done a comparison with just lipo in back,just agm and lipo and agm.... Front battery is a die hard platinum G34...alt is a DC 320amp...amp is a Ampere 8.0 TFE at .5....revving to about 1800-2k rpm full tilt voltage after about a 3 min song with just lipo was 12.3-12.4....same conditions with just 3 Northstar G31s in back was 11.6-11.8...with agms and lipo 12.8-12.9 full tilt after 3 songs....lipo is a juice box 40ah 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
hdorre Posted September 20, 2016 Report Posted September 20, 2016 I've been summoned. Nah. Bye bihh. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
SPL.Pantie.Soak Posted September 20, 2016 Author Report Posted September 20, 2016 I asked this question because I will soon be going the lithium route, I will be sure to do my best to document my experiences. And if I somehow manage to blow my car up I will try and atleast get it on video. (no juicebox or XS or whatever- I like my money) Kenwood KVT-614 (4) Marathon 155 AH batts 2/0 OFC SHCA Mechman 370 (2) Audioque 3500.1 (2) AA Mayhem 15s
DubNDodge Posted September 20, 2016 Report Posted September 20, 2016 I'm going lithium in the spring with tax return. 100A of alt from my bullshit car. 138Ah of AGM isn't going to support ~4k clamped. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
WalledSonic Posted September 20, 2016 Report Posted September 20, 2016 I've done a comparison with just lipo in back,just agm and lipo and agm.... Front battery is a die hard platinum G34...alt is a DC 320amp...amp is a Ampere 8.0 TFE at .5....revving to about 1800-2k rpm full tilt voltage after about a 3 min song with just lipo was 12.3-12.4....same conditions with just 3 Northstar G31s in back was 11.6-11.8...with agms and lipo 12.8-12.9 full tilt after 3 songs....lipo is a juice box 40ah MMM that data feels so good. Kali, youre running more alternator amperage than some of us are, but it seems you were fairly consistent with your test. So it seems that even though we wont be able to expect the same numbers on actual voltage values, the differential voltage between each setup is somewhat reliable info. Me rikey. I have an empty spot under the hood since I relocated my batteries to the trunk. I may drop a Group 34-sized lithium in that spot and see how it goes. I'm also not planning on running half ohm at this point, either, so I'm now a bit more excited about lithium. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
SPL.Pantie.Soak Posted September 20, 2016 Author Report Posted September 20, 2016 I'm convinced i can't afford them. lol We will all go eventually when the costs come down to levels where people can afford them, but it takes time for manufacturing to invent new processes that costs less to produce. Edit nvm fam Kenwood KVT-614 (4) Marathon 155 AH batts 2/0 OFC SHCA Mechman 370 (2) Audioque 3500.1 (2) AA Mayhem 15s
_paralyzed_ Posted September 20, 2016 Report Posted September 20, 2016 I've been running lithium for 10 years. R/C or die fools.
Broke_Audio_Addict Posted September 20, 2016 Report Posted September 20, 2016 I've done a comparison with just lipo in back,just agm and lipo and agm.... Front battery is a die hard platinum G34...alt is a DC 320amp...amp is a Ampere 8.0 TFE at .5....revving to about 1800-2k rpm full tilt voltage after about a 3 min song with just lipo was 12.3-12.4....same conditions with just 3 Northstar G31s in back was 11.6-11.8...with agms and lipo 12.8-12.9 full tilt after 3 songs....lipo is a juice box 40ahMMM that data feels so good. Kali, youre running more alternator amperage than some of us are, but it seems you were fairly consistent with your test. So it seems that even though we wont be able to expect the same numbers on actual voltage values, the differential voltage between each setup is somewhat reliable info. Me rikey.I have an empty spot under the hood since I relocated my batteries to the trunk. I may drop a Group 34-sized lithium in that spot and see how it goes. I'm also not planning on running half ohm at this point, either, so I'm now a bit more excited about lithium. I wouldn't put a lithium batt under the hood, They don't like heat. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
WalledSonic Posted September 20, 2016 Report Posted September 20, 2016 Good point Broke. 130degF limiting temp is certainly not conducive to being under the hood. Also, 28Ah out of a G34 sized battery isnt enough to even bother with, so i'd probably be better off stuffing an AGM in there. Im gonna need to make room in the back for a G31 sized lithium. Does anyone have experience with varying lithium types such as Li-Ion, LiPo, and LiFePo4? Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
Kyblack76 Posted September 20, 2016 Report Posted September 20, 2016 Just dropped a bit of money for the new bank..... we looked into lipo,.... maybe well do it in the future, for now,...... just rolled with what we know. Dont mean we wont change in the future. Or, maybe we wont. Time will tell. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
