Weird popping whenever I turn on my car
I have this weird popping sometimes when I turn on my car (even with my volume set to 0) and when I look back at my amps the Rockford Punch 4 channel flashes its input clipping light once or twice.
Head Unit: 80 PRS (Active setup) - Internal Amp is set to off / Eq is flat
RCAs: Rockford Fosgate 20 ft (3 pairs)
Car: Honda Civic Coupe 2008
Amps: DC 2k / Rockford Fosgate P600x4
All gains set with DD-1
The only thing I can think that could be causing an issue is either something with the head unit or the place I am using for my remote lead. I am hooked into the in cab fuse block onto a fuse that only puts out power with ignition via an add a circuit. The remote wire is 18/16 gauge.
Should I be worried about this popping / signal clipping? It only happens when I start the car never when I am playing music or go to turn the car off.
Another thing I think it could be is somehow my head unit is connected to the speaker/chime that is for my turn blinker, seat belt warning, etc.
Anyone have similar issue or tips on diagnosing this? Cheers
Well what makes you think the head unit is connected to the chimes ect? That would be odd considering you have an active front stage, i dont think thats the case.
Personally, i would move the remote wire over to the 80prs and check again, if same issue then check wiring to 4 channel
Its possible your current accessory source turns on before the 80prs, this can cause a pop with certain amps.
'08 Civic deck is not connected to anything operational in the vehicle so you can eliminate whatever that thought was.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
4 hours ago, reedal said:
https://ceautoelectricsupply.com/car-audio-products/turn-on-relay-kits/
you can always try putting a relay on remote turn-ons.... :)
This^^^
It's what I've always done
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
When I was tuning the car I had all speaker wires disconnected, but the head unit still had sound when browsing through the menus. I think the case is what you mention, that the amps are turning on before the head unit creating the pop/signal clip.
I considered a relay but decided to not use one because I have only two amps.
I'm going to switch over from using the interior fuse block to the head units turn on lead and see if that works.
Thanks for the replies guys.
The 80prs has a small piezo speaker built into the head unit, thats were the beeping is from.
If installed correctly, Your amplifiers should not be turning on before your head unit is ready for them ... I'd recheck your wiring. Installing a relay will only entisify the pop.
Just verify before anything that your amplifier turn on is connected correctly to your head unit. This would be my first observation. hope it helps.
  • Who's Online   1 Member, 0 Anonymous, 1572 Guests (See full list)
