Extending speaker wire with solder okay?
Joshdashef
Going to be moving my mids and high amp eventually but I may need to extend my speaker wire or re-run four pairs of wire. That is why I was wondering if I could just extend each run another 2-3 feet at most with solder connections at the end of where they reach now? Instead of re-run all four pairs....
Does this hurt the quality of sound output? anything I should worry about doing this? Wires 14 gauge if that matters powered off a P600x4 mids on two channels tweeters on two channels. Will be using the same wire to solder and extend if I go this route.
no real issue, may melt some of the jacket near the solder joint b/c the gauge of the wire.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
  • 2 months later...
On 4/6/2019 at 8:15 AM, Dragonsyph said:
Cca or ofc wire?
Good question. Can't solder CCA!
I would just braid the wire together very strong and heat shrink it , I stopped soldering wire years ago unless it’s on a circuit board . Had a class on this awhile back and braided and crimp joints hold better then solder. Solder isn’t flexible and can crack from vibration. Not to mention only about half the people that solder really know how to do it right , U don’t just put a drop of solder on a wire and call it soldered I’ve seen this a ton in car audio.
  • Who's Online   0 Members, 0 Anonymous, 933 Guests (See full list)
