Antoni Čović Posted May 29, 2019 Report Posted May 29, 2019 What is maximum charge voltage that average car can safely endure? Thanks
Ron36 Posted May 29, 2019 Report Posted May 29, 2019 I wouldn’t go over 15v , my truck hits 15.2v at times but U go to high and PCM’s fry . Also every manufacturer is different some PCM’s might turn off before damage . It’s a hard thing to follow but safe is always 14.7v. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
SnowDrifter Posted May 30, 2019 Report Posted May 30, 2019 It varies from vehicle to vehicle tbh. I think 14.7 is a bit conservative given that PCM controlled smart charging systems go into the 15+ range. My tahoe charges at 15.2 before dropping down to 13.1. My old subaru would tolerate 16.4 before the ABS went into safe mode and shut down. It burned through halogen bulbs like potato chips though. I eventually got most everything swapped to LED FWIW: Consider an alternator failure that might push a stock charging system to the 16-17v range. The systems have a pretty wide range of both voltage and temperature conditions they're intended to run at. This is by no means a guarantee of safety. More of a contextual piece of info. If you're not willing to test limits yourself, see if you can contact either the manufacturer or a local shop to see if they have access to documentation on voltage ranges of various modules. If you could provide more info on the project you're working on, perhaps we might be able to suggest a better solution ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Antoni Čović Posted May 30, 2019 Author Report Posted May 30, 2019 16 hours ago, SnowDrifter said: It varies from vehicle to vehicle tbh. I think 14.7 is a bit conservative given that PCM controlled smart charging systems go into the 15+ range. My tahoe charges at 15.2 before dropping down to 13.1. My old subaru would tolerate 16.4 before the ABS went into safe mode and shut down. It burned through halogen bulbs like potato chips though. I eventually got most everything swapped to LED FWIW: Consider an alternator failure that might push a stock charging system to the 16-17v range. The systems have a pretty wide range of both voltage and temperature conditions they're intended to run at. This is by no means a guarantee of safety. More of a contextual piece of info. If you're not willing to test limits yourself, see if you can contact either the manufacturer or a local shop to see if they have access to documentation on voltage ranges of various modules. If you could provide more info on the project you're working on, perhaps we might be able to suggest a better solution I have fiat punto mk1 and I was thinking to get Yinlong LTO batteries.. I heard that I need a little higher voltage to get all of them.. Thats why I'm asking.
BassMunky Posted May 30, 2019 Report Posted May 30, 2019 15 v system? Ummm Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
SnowDrifter Posted May 30, 2019 Report Posted May 30, 2019 2 hours ago, Antoni Čović said: I have fiat punto mk1 and I was thinking to get Yinlong LTO batteries.. I heard that I need a little higher voltage to get all of them.. Thats why I'm asking. 5s pack and charge at 13.8? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
White Lightning Posted May 30, 2019 Report Posted May 30, 2019 21 hours ago, Antoni Čović said: What is maximum charge voltage that average car can safely endure? Thanks Average vehicles run a 12 volt system for a reason ... Just Saying Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
Antoni Čović Posted May 30, 2019 Author Report Posted May 30, 2019 2 hours ago, SnowDrifter said: 5s pack and charge at 13.8? 5x2.3v is 11.5v.. I just heard that to get all of them you need over 14.4v and that 14.4v is minimum to charge them.
Kyblack76 Posted May 30, 2019 Report Posted May 30, 2019 Ecu on vehicles is different. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
SnowDrifter Posted May 31, 2019 Report Posted May 31, 2019 1 hour ago, Antoni Čović said: 5x2.3v is 11.5v.. I just heard that to get all of them you need over 14.4v and that 14.4v is minimum to charge them. I wouldn't touch lithium if I were you ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
