So i heard of this thing called "Daisy chaining" amplifiers together. I read that if done properly you can chain like, 10 amps together [not that someone would] and get massive pooowwwwaaaaa. only problem is if i remember correctly that each amp needs its own power source [im not sure about signal]. Now, how can this be done? is there some power and ground isolation things i can hook up to the power and ground to make this happen? i do really want to try this.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
Where in the world did you hear that??
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
imma do it.
Lots of Second Skin
:WTFBubble:
:WTFBubble: What I want to know is, what fricken sub was he planning on running with the 5 amps and at what ohm load ?
truthsayer
Jackhammer ??
If you had put them in parallel you might have actually done something feasible.. if you time corrected the signal to each one and carefully matched their outputs, among other things.
As it is: LOL.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1651 Guests (See full list)
