jakeryan Posted July 21, 2012 Report Posted July 21, 2012 Looking to build an enclosure with a 21 inch subwoofer for my room. Already have the Polk Audio Psw10 10 inch woofer for strong punchy bass but, I want a extremely low end punch which sadly, the 10 inch driver will not provide. Probably going to build a 14 foot or so cubic feet enclosure for a 21 inch subwoofer. Then probably buy a lanzar 2000 watt amp or something to power it. Any suggestions on if I should even spend the $155 for the project or should I just ditch the idea. The item number is PYLE-PRO PDW21250 (Pic of the sub below) B.T.T.M -Jake Ryan
CleanSierra Posted July 21, 2012 Report Posted July 21, 2012 Why did you make this same thread twice? An hour apart? Im not the one you want to try to troll. Just a fyi for you.
graham0599 Posted July 21, 2012 Report Posted July 21, 2012 One is in home audio and one is in the general category. I was confused too haha My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
jakeryan Posted July 21, 2012 Author Report Posted July 21, 2012 Felt like I wanted to "switch" It to home audio. But couldnt find out how to delete the other thread. B.T.T.M -Jake Ryan
beaker Posted July 22, 2012 Report Posted July 22, 2012 If you're going to make it for your home I would go ahead and just use a plate amp. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-752 That should more than handle that sub, you can also use a rack amp. I wouldnt try to use a car audio amp to power it.
MrSkippyJ Posted July 22, 2012 Report Posted July 22, 2012 i don't see any reason that 10" sub couldn't do what you need it too if you built an appropriate enclosure. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
kirill007 Posted July 22, 2012 Report Posted July 22, 2012 if the ten inch woofer can't provide you of low bass, you have to redesign the enclosure for it. The pyle woofer isn't made to give you the lows. You need a subwoofer to get the lows. Thinking is the root of all problems... You ALWAYS get what you pay for.
Omega5002 Posted July 22, 2012 Report Posted July 22, 2012 Why build a refrigerator sized box when either a 10' or 12' can achieve what you want with proper design. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
carlosg_313 Posted July 22, 2012 Report Posted July 22, 2012 Let the man do what he wants, and then let him learn. How do the Japanese feel about bass?You know that since 03/11/11 Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.im pretty sure the op wont even notice if it gets even smaller. Refs - Pstone11, porksoda, coleman
Guest Posted July 22, 2012 Report Posted July 22, 2012 dont forget about room placement. thats another huge problem you have to solve.
