11133660_1579566248962118_24306832344316
Brazil vs. Korea vs. "'Merica"
Round 1.
I call this one "max useable" because all I do is keep turning it up until it stops gaining on the meter. I record the score and the clamp at the loudest point with no regard to clipping or distortion.
(3) beefy 3" coil subs in a daily box were used for the testing to keep thermal issues at a minimum.
Every amp saw .66 nominal rising to 2.4. Side note for those who think different amps have different impedance rise... Nope.
Due to the nature of "clamping"... Output numbers are rounded to the nearest 100w.
- Banda Ice 4000
-- 2,900 var
-- 152.1dB
- Taramps HD4000
-- 2,900 var
-- 152.1dB
-Twisted Sounds 3.5kW
-- 2,600 var
-- 151.6dB
-MMATS 4000
-- 2,200 var
-- 151.3dB
Edited by DubNDodge
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Brazil vs. Korea vs. "'Merica" Round 1. I call this one "max useable" because all I do is keep turning it up until it stops gaining on the meter. I record the score and the clamp at the loudest point with no regard to clipping or distortion. (3) beefy 3" coil subs in a daily box were used for the testing to keep thermal issues at a minimum.
- Banda Ice 4000
-- 2,900 var
-- 152.1dB
- Taramps HD4000
-- 2,900 var
-- 152.1dB
-- 2,600 var
-- 151.6dB
-MMATS 4000
-- 2,200 var
-- 151.3dB
Im all sorts of confused here. Which amp is the American? The mmats? Or the twisted sounds? Exact same output from the tar amps and Banda huh? And of course mmats is a full db off and by far the least put. I can't wait til someone starts attempting to discredit that one because we all know they are the best amps ever.
Was this a tfade test?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
welcome to the ghetto.. its been 3 hours and the sheriff is still there.. this is the main street where i live.. 2 things could have happen.. someone got murdered or they robbed the liquor store again but what its different is that the cops been there for hours not like before so someone is dead
the main road is closed and everyone is turning in my block
just came
936230_487291967992946_1119865120_n_zps8
Woofer porn much?
  • Like (+1 Rep) 2
Current build
300amp alt
(1) xs power d4800 up front
(1) Optima yellow top 34 out back
All 1/0 skyhigh car audio power and ground including big 3/4
(2) Hyphonics 2000.4
front doors 5.25" memphis mclass comps don't recall exact model#
future plans to run (2) pair 6-8" mids each front door.
rear ski port 6.75" Alpine Type X pro series running passive
rear doors factory 5.25" need better speakers.
(1) ? sub amp maybe sundown saz-4500d
(1) ? Subwoofer maybe team 15"
getting by with a db drive 2400.1 class ab amp thats doing a good 660ish
watts rms to single JL audio 13w6v2 @ 2ohms
box 2.86 cubes slot port 32hrz
def need way more batteries.
https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate
- Banda Ice 4000
-- 2,900 var
-- 152.1dB
- Taramps HD4000
-- 2,900 var
-- 152.1dB
-- 2,600 var
-- 151.6dB
-MMATS 4000
-- 2,200 var
-- 151.3dB
Yupp tfade test. Posted to fb 2 hours before I posted this. And I believe the mmats is american made. not sure about twisted sounds. But legit test is legit, especially being tfade. I figured this would release all sorts of chaos here
- Banda Ice 4000
-- 2,900 var
-- 152.1dB
- Taramps HD4000
-- 2,900 var
-- 152.1dB
-- 2,600 var
-- 151.6dB
-MMATS 4000
-- 2,200 var
-- 151.3dB
The mmats is US made, the thing to remember here is that the mmats is rated at 4k rms @ 1ohm and 13.8v. The Taramps is 4798w rms @ 1ohm and 13.8v, Banda is 4600w rms @ 1ohm and 14.4v. The twisted sounds amp is 3.5k @ 1ohm and 14.4v but come on what 3.5k board had dual inputs and is the size of a 5k? Not discrediting it at all, seems like a solid amp but it makes more than 3.5k. So in my mind the mmats makes the least "rated" wattage, but it still is making it's 2 ohm rated wattage. I don't see anything wrong with that.
- Banda Ice 4000
-- 2,900 var
-- 152.1dB
- Taramps HD4000
-- 2,900 var
-- 152.1dB
-- 2,600 var
-- 151.6dB
-MMATS 4000
-- 2,200 var
-- 151.3dB
A good test is a good test, tfade always does us right. I think the results are very in line with what the amps have to offer. Sometimes the normally accepted isn't always the best option.
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
Twisted Sounds is making some pretty solid stuff. One of the loudest stock SUV guys loves the 8.5k, heath lay out of Texas.
- Banda Ice 4000
-- 2,900 var
-- 152.1dB
- Taramps HD4000
-- 2,900 var
-- 152.1dB
-- 2,600 var
-- 151.6dB
-MMATS 4000
-- 2,200 var
-- 151.3dB
MMAT's is USA, Korean is Twisted, Brazilian are the two there that you love so much.
