audiofanaticz Posted June 1, 2015 Report Posted June 1, 2015 I must have bad taste, because those animal crackers along with any other brands suck compared to these. Plus you get a cool little carrying handle unless you buy them in the bag! 4 Quote
Broke_Audio_Addict Posted June 1, 2015 Report Posted June 1, 2015 Went through hell getting this in and not to happy with the light out put. Either i have 2 bulbs installed wrong, and if that dont work i just need to find brighter bulbs. Wider angle bulbs is what you need. Had the same issue on my motorcycle and switched them out for wider angle bulbs, problem solved. Quote That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Krakin Posted June 1, 2015 Report Posted June 1, 2015 Anything over 55 is too fast and anything under 2k is too low. so don't worry. 2 Quote Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
OrionStang Posted June 1, 2015 Report Posted June 1, 2015 Anything over 55 is too fast and anything under 2k is too low. so don't worry. Fucking retarded. Quote SMD Super Seller My Feedback Thread
bolanorthhighlands Posted June 1, 2015 Report Posted June 1, 2015 Fail: Dude Gives Car Engine Nitrous It Cant Handle! http://www.worldstarhiphop.com/videos/video.php?v=wshhZi0264TThQhBkTcM 2 Quote My 2002 Kia Spectra LS My YouTube Channel
Miguels Posted June 1, 2015 Report Posted June 1, 2015 seen it happen after the first fast and furious first came out. every idiot with a honda put nitrous on it and blown engines everywhere.. stock crank, pistons rings, and heads im sure it pinged to death.. even with forged crank and pistons your block can blow. you need to retard the timing and get the correct plugs Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Katt Posted June 1, 2015 Report Posted June 1, 2015 Went through hell getting this in and not to happy with the light out put. Either i have 2 bulbs installed wrong, and if that dont work i just need to find brighter bulbs. Wider angle bulbs is what you need. Had the same issue on my motorcycle and switched them out for wider angle bulbs, problem solved. You probably have some backwards lol. I would of tested before i put it back together. Also, these are what you need, They shine in each direction. I have 6? in my dashboard in my fox, and its wicked bright. Even blue LEDs with a green backface, it shines through blue with no green tint. http://www.ebay.com/itm/20-PCS-Super-White-T10-Wedge-5-SMD-5050-LED-Light-bulbs-W5W-2825-158-192-168-194-/201331107137?hash=item2ee044e541&vxp=mtr Quote *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch*
ProMaxx316 Posted June 1, 2015 Report Posted June 1, 2015 Anything over 55 is too fast and anything under 2k is too low. so don't worry. Quote If it's worth building, it's worth over building.
ProMaxx316 Posted June 1, 2015 Report Posted June 1, 2015 And i did test them out. Just couldnt tell since it seemed like the sun wantes to beam down right into my truck. And this cluster was a pain in the ass. Mainly the speedo cable. Quote If it's worth building, it's worth over building.
Andrew Storlie Posted June 1, 2015 Report Posted June 1, 2015 Anyone else have these issues? https://www.youtube.com/watch?v=JPm4aZwuV_Y&feature=youtu.be Quote
