MrSkippyJ Posted June 9, 2015 Report Posted June 9, 2015 Your new car? it's probably able to adjust the timing to gain horsepower when you run a higher octane. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Miguels Posted June 9, 2015 Report Posted June 9, 2015 its the timing N8.. not the fuel. with more octane the timing on computer controlled cars advances. with lower octane the timing is retard.. i dont believe octane increases hp. the times i seen te improvements are on the dyno after the timing gets tweaked for the better fuel Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
MrSkippyJ Posted June 9, 2015 Report Posted June 9, 2015 its the timing N8.. not the fuel. with more octane the timing on computer controlled cars advances. with lower octane the timing is retard.. i dont believe octane increases hp. the times i seen te improvements are on the dyno after the timing gets tweaked for the better fuel That is exactly what it is. Unless the octane is keeping the engine from operating at full potential (i.e. detonating from compression rather than from the spark) then octane won't increase any kind of output. 1 Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
bolanorthhighlands Posted June 9, 2015 Report Posted June 9, 2015 LoL 4 Quote My 2002 Kia Spectra LS My YouTube Channel
audiolamb6 Posted June 9, 2015 Report Posted June 9, 2015 had my uncle make these up for me while my mom was in cali not the size i wanted but it will work Quote
Azagtoth502 Posted June 9, 2015 Report Posted June 9, 2015 Stand up for what you believe in. https://www.youtube.com/watch?v=NbbFiTMn_ok&feature=youtu.be 2 Quote pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
Quiet Posted June 9, 2015 Report Posted June 9, 2015 U need gas that matches the engines performance Sorta, you can run a higher octane that you need, you just don't really get any benefit. my brother had a 429 out of an older t-bird he put in his pickup. couldnt run anything less than 92 or it would ping like a bitch Yeah that ping or knock is what happens when you run to low octane. Especially in older engines, todays engines can adjust timing and all that shit to accommodate for when the fuel detonates to a certain extent. That is true. However some cars retard the timing so much on lo-test that performance is down right shitty. Wifey rented a Maxima when her car was in the body shop for hail damage. We ran one tank of 87 and the car just dogged so bad i think I could've out run it with the impala. Put in 93 and it takes off like a bat out of hell. But Mario's explanation of octane is right on. It's simply the fuel's resistance to detonation, and higher compression engines can cause low octane fuel to detonate before the spark, and that's not so great for your motor. There's no more "power" in higher octane gasoline, just refined to burn smoother and when you want it to. Another way to think about it is that higher octane fuel burns more precisely than lower octane, and higher compression motors need a more precise burn. Quote 2007 Pacifica Rebuild. Less quiet. Still not loud.
OrionStang Posted June 9, 2015 Report Posted June 9, 2015 Dickhead parking. The truck (on the left) was parked there first and is centered in the spot. How is the owner supposed to get in with the way the van has parked. At least the van driver folded in the mirror *sarcasm. Cocksucker. Ain't my vehicle, but still. Quote SMD Super Seller My Feedback Thread
reedal Posted June 9, 2015 Report Posted June 9, 2015 The higher the octane the fuel the more compression it can withstand before it detonates. In higher performance engines, the compression is usually higher than the average engine. Most people run higher octane in those engines to prevent premature detonation. As long as you run an octane high enough to withstand the amount of compression in your engine there is usually no benefit to running a higher octane. Hope that makes some kind of sense to you. How does one determine the amount of compression in order to figure out the octane they should be using? Quote SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
MrSkippyJ Posted June 9, 2015 Report Posted June 9, 2015 Read the manual that's all I know to be honest. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
