I have one of two Fi Bl 18's in a wall and have noticed that there is a ton of heat building up after a short period of play on both test tones and music. The box is 5 cubic feet (probably a bit on the small side) and the sub is being powered by a Kicker ZX2500.1. Also the sub seems to have only a small amount of excursion and I don't feel like that's the way it should be... Any help you can give me would be appreciated! Thanks!
'03 Cavalier LS Coup
DC Power 270xp alt
2 Sundown Neo Pro 8's
2 Selenium ST200 tweeters
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
1 CT Sounds AT7000.1D
No, sorry they are in separate chambers 5 cubes per. The chamber is 21 deep x 18.5 wide x 19.5 tall the port is 21 deep x 18.5 wide x 2.5 tall. After displacement and all that jazz the chamber is 5.01 cubic feet and the port is tuned at 31.2 hz
DC Power 270xp alt
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
If I'm not mistaking FI tend to like bigger boxes, u should have about 6-7cu chamber per 18. (depending on power ran).
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
2500 per sub ? That is way too much for a BL, for music.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a 2.6 ft3  ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
