So i heard of this thing called "Daisy chaining" amplifiers together. I read that if done properly you can chain like, 10 amps together [not that someone would] and get massive pooowwwwaaaaa. only problem is if i remember correctly that each amp needs its own power source [im not sure about signal]. Now, how can this be done? is there some power and ground isolation things i can hook up to the power and ground to make this happen? i do really want to try this.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
Where in the world did you hear that??
Krakin's Home Dipole Project
imma do it.
Lots of Second Skin
:WTFBubble:
:WTFBubble: What I want to know is, what fricken sub was he planning on running with the 5 amps and at what ohm load ?
truthsayer
Jackhammer ??
If you had put them in parallel you might have actually done something feasible.. if you time corrected the signal to each one and carefully matched their outputs, among other things.
As it is: LOL.
Hammerdown... 1%
  • Who's Online   1 Member, 0 Anonymous, 658 Guests (See full list)
