Fi SP4 subwoofer enclosure sizes?!?!?!?
drumstar7
I am doing away with my 4x12 setup and going to a 2x18 setup with Fi sp4's. I plan on running one Crescendo BC 5500 on each subwoofer wired down to a single ohm on each amp.(not strapped.) I wanted to build a custom dual chambered ported box for this setup and so far I have a few ideas of my own but am very unsure if it will give me the most spl and output!!! I can go 48Wx32Hx28L maybe even 33H
39.5x31 face
48x28 top
48x28 bottom
27x31x27x31 port L
26x31x26x31 right
48x31 back
22.5x31x22.5x31 tuned to around 30hz and 32ish after sub displacement.. 8Cubes per sub. too big or? I open for Ideas, I have plenty of power for the amplifiers MM Elite 370 and three HC1800, 60 feet of 1/0 RF OFC
Maybe a single 5500 if that per sub. They are underrated at 3000 wrms and putting almost x4 the power is not a good idea.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Where do we start?
-Sub thermal and mechanical power handling
-That enclosure idea
-Your subpar electrical setup
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I'm confused are you putting a 5500 on each sub or two 5500s PER sub. The way you've worded it shows you're throwing 11k rms to each sub.
Syphlyns 2000 F150 4.6L V8
H/U: Kendwood KDC-X898
Speakers: 4 x Alpine SPR-68 Speakers
4 Channel Amp: Alpine PDX-F4
Sub: Sundown Zv4 12
Sub Amp: Sundown SAZ-2000D
Box: 2.75 Cu Ft @ 31Hz
Alternator: Mechman 250A elite series
Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
Look one BC 5500 per sub is not going to hurt anything, I want to run it less than half power. In the sense clean power no clipping from amps or subs. Also these amplifiers have no fans and at one ohm half power it would be less heat. I just need some enclosure ideas and I also was leaning toward 8cubes of airspace. I was told these subs do great in larger boxes.
  • Who's Online   0 Members, 0 Anonymous, 5175 Guests (See full list)
