Mechman Alternators
The Highest Output Alternator is Not Always the Best Option!!!
hasnt been driven since june.lol door panels are even off
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Mechman told me same thing about the 4.6 alt, my singer 350 is still going strong though.......
even singer told me their has been an issue on some 4.6's with belt slip due to shitty belt wrap.. its not unheard of for it to be a problem it just doesn't always become a problem
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
my truck cruises at like 800 rpm. it barely turns the alt on. if I ever drive it again im thinking about going to a third with high idle so I can balance out
Damn dude! That kinda sucks. My car has a smalllllllllll 4 banger in it so if I'm doing 60 mph down the interstate, im at 2500 rpms and if I do 70 mph then its closer to 3k rpms.
Edited by Slinky
DD M4
Rockford Fosgate P500-4
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Mu car sots between 1500-2500 while driving (depends on where in going). The 250amp singer alt puts out at 1700-2k rpms. I don't sit at an idle full tilt.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I have a 2000 f150 and wanted the 270A unit from mechman. Called them and they told me that would be bad for my truck due to the limited belt wrap on the 4.6l/5.4l engines from ford at that time period. They said they've had way less issues with the 240A unit. Saved me $100 and probably a mountain of issues.
lololol you serious? buddy of mine has a crown vic with the 4.6 and has a dc power 270xp on it. i never heard his belt make so much as a peep when demoing full tilt with 20k.
That's what I'm told. Slipping isn't always audible just look for the black dust on the alt. You sure the crown vic and the F150 engine bay is identical? Like how the belt is set up and routed? If he has ac/doesn't have ac that could change the way it wraps around the alt too. I highly doubt the crown vic and the f150 have identical engine bays and pulley system.
Regardless having the 270A for a 2000w amp is overkill anyways...
Syphlyns 2000 F150 4.6L V8
H/U: Kendwood KDC-X898
Speakers: 4 x Alpine SPR-68 Speakers
4 Channel Amp: Alpine PDX-F4
Sub: Sundown Zv4 12
Sub Amp: Sundown SAZ-2000D
Box: 2.75 Cu Ft @ 31Hz
Alternator: Mechman 250A elite series
Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
Yeah I continually run at 13.5 or so too. Last time I tried an AVBM it went up in smoke and almost took the truck with it. i'll deal with it.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Ninja knows nothing about Slam or getting drunk there or showing up in parking lots with an AK strapped to him.
little birdy said it was an ar-15 and it was for protection of all you guys.. never know how wants to show up and try to get free batteries or steal the vodka
:peepwall:
:ninja:
Edited by sensai_v4.0
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
maybe instead of just posting, get the biggest one that will fit! we should recommend contacting the person who is going to make your alternator.then you can explain what your set up is going to be.Me personally, i wouldn't just order an alt online without research and talking to someone. even though one place tried to sell me a quad setup for running 10k. Talked to Singer afterwards,and he said ,i have 1 that will run your system no problem! never looked back! Excellent info in this thread also :good:
  • Who's Online   1 Member, 0 Anonymous, 1515 Guests (See full list)
