Orfeous Posted April 19, 2015 Report Share Posted April 19, 2015 I want to wire the sub to 1ohm with 8awg powercables. And then to my box terminal. My woofer accept 8awg. I have tried to put in two but it nearly fits. Rockford Fosgate T2D212 I have read that this can be solved when do the wiring internally in the box. Can I please see some example pictures of how you people do? Link to comment Share on other sites More sharing options...
Hugh G. Rection Posted April 19, 2015 Report Share Posted April 19, 2015 I usually would take the 2 8ga wires and solder them together with a third wire coming out to go in the sub. Owner of BigAss Ports Link to comment Share on other sites More sharing options...
sideshow_kustom Posted April 19, 2015 Report Share Posted April 19, 2015 I usually would take the 2 8ga wires and solder them together with a third wire coming out to go in the sub. ^^^^^ Good ideal and would b less expensive then another option! You could buy adapters from ToolMaker to do it to but then you get into some money! Drive In Theater Speaker Build http://www.stevemead...-speaker-build/ Suitcase Build http://www.stevemead...ld-in-bis-kwik/ Coleman Cooler Build http://www.stevemead...ld-in-bis-kwik/ X10 Box Build http://www.stevemead...under-bis-kwik/ Complete Build Log On Bis-Kwik http://www.stevemead...13-wagon-build/ NEW SUB'S 8 SundownAudio X6.5sw Build http://www.stevemeadedesigns.com/board/topic/197034-new-wagon-build/ Link to comment Share on other sites More sharing options...
Orfeous Posted April 19, 2015 Author Report Share Posted April 19, 2015 Ok but what about screws or bolts to the box wall? One cable for each speaker terminal so i end up with three cables there one is going to box terminal? Link to comment Share on other sites More sharing options...
Big-A Posted April 19, 2015 Report Share Posted April 19, 2015 Use ring terminals on each lead. Then you can screw them together on the inside of the box or through bolt with a pinch nut. 2004 Dodge Ram Head unit- Alpine iDA-x305s Sound processor- Clarion eqs746 Mids/Highs amp- Alpine MRV-F345 Sub Amp- Alpine MRD-M1005 Dash Speakers- (3) Dayton Audio rs75 Front Door- Skar SPX65c Rear fill- Skar SPX tweters and Dayton ND140 midbass Sub- Fi Audio SSD 15 high QTS SHCA power/ground cables and Stinger interconnect XS power D6500 under the hood and D680 in the amp rack Big 3+ with SHCA http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251 Link to comment Share on other sites More sharing options...
islandpride684 Posted April 19, 2015 Report Share Posted April 19, 2015 That is how mine is setup, 2 bolts, 4 washers, and a nut, 4 wires, 4 ring terminals, then wired to the bolts, then from outside to the amp... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
Orfeous Posted April 19, 2015 Author Report Share Posted April 19, 2015 Ah.. ok. Might try a T-nut with a little bolt. Or just short woodscrews. I hope that the screws dont fall off maybe i can put some glue of any kind in the screwhole? Link to comment Share on other sites More sharing options...
Orfeous Posted April 19, 2015 Author Report Share Posted April 19, 2015 My ring terminals are this: The ring hole is 4.3mm So i dont think a bolt will fit. Otherwise i must use a very small bolt. So i think wood screws is the best Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted April 19, 2015 Report Share Posted April 19, 2015 Binding post. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
MrBigs63' Posted April 19, 2015 Report Share Posted April 19, 2015 Don't use screws inside the box to hold the ring terminals together. Like it was said earlier, you can put two bolts through the side of the box. Attach both positive leads to one post and both negative leads to the other. Then you can connect your two wires on the outside to run to the amp. Also, when most manufacturers make the sub where two 8 awg wires won't fit in the terminal, that normally means that you don't actually need 8 awg. If Rockford thought you needed that large of wire, they would have made the terminals larger. Link to comment Share on other sites More sharing options...
