How to use rta??
I have access to a audiocontrol rta today, my eqs should be flat.. with volume 100% and I adjust the frequency on the eq (headunit) to get them close to flat? Am I right or wrong?
HU: Pioneer DMH-Z5350BT
Mids & Highs: ML280.3, ML700.3, ML1800.3 Mille Legend Series 3 way
Lows: x3 JL Audio 12TW3 powered by JL Audio RD1500/1
Cable: x2 Skyhigh 0 Gage OFC kits. Skyhigh 8 gage & 16 gage OFC speaker cable
Sound Deadener: 121 sq feet of Skyhigh 120mil
DSP: AudioControl DM 810
Project Build Log
Click here: 2001 Jeep Grand Cherokee SQ Build to see the build progress.
Opposite, i would tune my head unit flat then adjust on the rta.
Edit: also never put your volume at 100%, i would only do 75-80% so your head unit doesn't send an already clipped signal
I think you're lost on this one.
I've always been told that any signal going into a processor needs to be flat, if you adjust the signal at the source then whats the point in having an eq processor at all? I've also been told that most decks will send a distorted/clipped signal when turned all the way up, therefore you should only turn it up to 80% at most, then boost the signal at the processor instead.
An rta is a real time analyzer not a processor.
I don't know if you know this or not, but not every head unit clips at 100%... That yahoo answer "75-80%" crap isn't true either. There's head units that clip a lot sooner than that too. Using tools that allow you to see your signal or the distortion in it (oscope, spec-an, DD-1, and more), lets you find out where your head unit volume can go to. I can go 100% with no distortion or clipping
Do you have a "pink noise" disc track ?? Can't RTA without one ...
  • Who's Online   0 Members, 0 Anonymous, 826 Guests (See full list)
