sideshow_kustom Posted May 12, 2016 Author Report Posted May 12, 2016 Thanks guy's I've been hard at it the past week or so! Today I got the rest of the floor ready for Rhino-Lining, all rust removed and all the holes welded up! So I directed my attention back onto the Spare tire cover that will have the 2 Sundown Neo-Pro 10's in it. Well I didn't like the way some of it was made and felt like it just wouldn't have the correct curves to it once finished. SO I decided to make a mess and use some Great Stuff foam! After trimming most of that mess off of it was ready to hand sand the foam to better shape it After hand sanding time to cover it and get it ready for glass! Yep time to get itchy! Let it sit over night and cure out and start back working on it tomorrow to get it ready to Rhino-Line as well! Drive In Theater Speaker Build http://www.stevemead...-speaker-build/ Suitcase Build http://www.stevemead...ld-in-bis-kwik/ Coleman Cooler Build http://www.stevemead...ld-in-bis-kwik/ X10 Box Build http://www.stevemead...under-bis-kwik/ Complete Build Log On Bis-Kwik http://www.stevemead...13-wagon-build/ NEW SUB'S 8 SundownAudio X6.5sw Build http://www.stevemeadedesigns.com/board/topic/197034-new-wagon-build/
cgrez33 Posted May 12, 2016 Report Posted May 12, 2016 DA updates! Current Build: 1999 Tahoe #ComingSoon Previous Build(s): Crossfire Magnum 5k Pontiac G6 GT
sideshow_kustom Posted May 13, 2016 Author Report Posted May 13, 2016 Part's are stacking up at the painters! Time to finish the spare tire cover for the 2 Sundown Audio Neo-Pro 10's. Now that the Fiber-glass is cured time to trim it in. Time for some body filler! Time to start working this stuff down! Who know's about one of these bad boy's! All sanded down and ready for a coat of primer! Good coat of primer on it. If I had plans on painting it smooth I would of done a second skim coat of filler, block sanded, primered again and wet sanded the hell out of it. BUT since it will be a textured Rhino-Lining I feel like one coat will be good. sure it has some minor imperfections but I don't think they will be seen with a texture rhino-lining on it. I HOPE this statement don't bite me in the ass! Considering what it looked like I think even if it has some imperfections it is still a HUGE improvement! Drive In Theater Speaker Build http://www.stevemead...-speaker-build/ Suitcase Build http://www.stevemead...ld-in-bis-kwik/ Coleman Cooler Build http://www.stevemead...ld-in-bis-kwik/ X10 Box Build http://www.stevemead...under-bis-kwik/ Complete Build Log On Bis-Kwik http://www.stevemead...13-wagon-build/ NEW SUB'S 8 SundownAudio X6.5sw Build http://www.stevemeadedesigns.com/board/topic/197034-new-wagon-build/
sideshow_kustom Posted May 14, 2016 Author Report Posted May 14, 2016 See my problem is if I sit and think about something too long it will eat me up!!!!! After making the statement that it "Should Be OK" I just couldn't let it be sprayed without me being satisfied with it first! SO time to block sand it and see where my low spots are! I'm actually glad I did cause I realized that my latch system would not fit correct and needed clearance on it! Some more filler to even it out! Sanded down and still had a few small low spots Another coat of filler primer and sanded down with a lighter grit to work most of the scratch's out of it Last coat I decided to go with Black Primer since it will be sprayed with a Black Rhino-Lining Now that my arms feel like JELLO I'm done with it!!!! Off to the painters now!!!!! Drive In Theater Speaker Build http://www.stevemead...-speaker-build/ Suitcase Build http://www.stevemead...ld-in-bis-kwik/ Coleman Cooler Build http://www.stevemead...ld-in-bis-kwik/ X10 Box Build http://www.stevemead...under-bis-kwik/ Complete Build Log On Bis-Kwik http://www.stevemead...13-wagon-build/ NEW SUB'S 8 SundownAudio X6.5sw Build http://www.stevemeadedesigns.com/board/topic/197034-new-wagon-build/
cgrez33 Posted May 14, 2016 Report Posted May 14, 2016 Looks awesome man Current Build: 1999 Tahoe #ComingSoon Previous Build(s): Crossfire Magnum 5k Pontiac G6 GT
sideshow_kustom Posted May 15, 2016 Author Report Posted May 15, 2016 Did my last few touch's to the Spare tire cover before I drop it off Monday with the body shop to be sprayed. Got the latch bolted down as well as mounted the grill rings on it Also test fit it in the Wagon. Keep in mind I have all the other panels out that's why it looks like it don't fit exact! But looks good in there SO I have decided to make a BOLD move on it. I went ahead and removed the rear gate as well as the rear windows on it. Preparing my self for the next move. Drive In Theater Speaker Build http://www.stevemead...-speaker-build/ Suitcase Build http://www.stevemead...ld-in-bis-kwik/ Coleman Cooler Build http://www.stevemead...ld-in-bis-kwik/ X10 Box Build http://www.stevemead...under-bis-kwik/ Complete Build Log On Bis-Kwik http://www.stevemead...13-wagon-build/ NEW SUB'S 8 SundownAudio X6.5sw Build http://www.stevemeadedesigns.com/board/topic/197034-new-wagon-build/
Karkov Posted May 15, 2016 Report Posted May 15, 2016 Knew it was just a matter of time, LOL 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
ShadeTreeMechanic Posted May 15, 2016 Report Posted May 15, 2016 Awsome work! I like how you use the nylon sheet insead of wood. You took out the back glass and tailgate. If you think like me then I know what your up to! Cant wait to see it. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
sideshow_kustom Posted May 15, 2016 Author Report Posted May 15, 2016 Knew it was just a matter of time, LOL LOL yeah I know!!!!! It's on today with it!!! Drive In Theater Speaker Build http://www.stevemead...-speaker-build/ Suitcase Build http://www.stevemead...ld-in-bis-kwik/ Coleman Cooler Build http://www.stevemead...ld-in-bis-kwik/ X10 Box Build http://www.stevemead...under-bis-kwik/ Complete Build Log On Bis-Kwik http://www.stevemead...13-wagon-build/ NEW SUB'S 8 SundownAudio X6.5sw Build http://www.stevemeadedesigns.com/board/topic/197034-new-wagon-build/
askmeaboutmy6.5s Posted May 15, 2016 Report Posted May 15, 2016 Going through this whole thing when I get time! Planning a diesel? Gona be sweet! Follow Seth Sharer Designs on Facebook for more frequent updates! New build coming soon! 20 6.5s wall on two massive drago 5ks
