Mounting 1 amp underseat and 1 in passanger foot-well
You can PL glue wood to the metal. Then screw the amps to that. There are several epoxies all that. You can screw some angle iron to the metal, then wood to those, then amps to that. There is several ways to skin a install,... derrrr cat.
EDIT- fuck, id have no fear putting a board under a seat. If it fits, and can cool some, fuck,.. who cares. Did some one say it will get a lil dirty? Fuck, who cares. .....
Thanks man, thats what i was lookin for, ill try to look up those things. Ive never done this kinna thing so thats why im askin noob questions. My cars a 06, the underseat carpet looks brandnew besides a receipt and bottle cap and pen lol.
Pull the seat out so you can pull the carpet up to see what is under it. look under the car to see what the screws are going through.
Pioneer 80PRS
If you're going to screw/drill through the body, and you do so without seeing what's on the other side that you may or may not put a hole in, then you had no business putting holes there in the first place. WE don't know what is in those places you want to mount. Use common sense and look at where you want to drill/screw. If you can't see that spot, because your trans or gas tank or whatever else is in the way, then find a different spot.
Personally, I'd rather glue/epoxy a board, than putting holes in my ride.
Yah im really leaning toward that idea of glue or epoxy. i could put some threaded inserts into the board and epoxy that to the bare metal body, than mount the amp to that board. Can u recommend some glues/epoxys that are really good for this type of application?
PL premium would be effective.
Another option is using factory bolts that are already protruding from the floor. When you remove everything and lift the carpet to apply your deadener, you may find multiple locations with bolts that aren't being used. Same thing with grommets for passing your wiring through if you run it under the body. The holes are already there, might as well use them.
Is loctite a high quality brand to go with? Or is that generic? Thats the first one that comes up when i google PL glues or epoxys.
Yah i found a pretty good path under the car, and a couple perfect spots up front to run the wire to the under body. At the rear i found a good spot but ill have to drill it out with one of those grommet hole drill bits, i forget the name of it lol. Just savin up a few bucks for the wire, terminals, fuses/holders and some loom/conduits.
I wouldn't use pl, you'd be making it permanent,
and that shit is nasty.
wire length costing too much? You are in the wrong hobby, shot costs money......
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
