"Shadow" 2016 Jeep Wrangler JK/4th Order/(4) 8's/DC 3.5K/Large Case Hairpin US Alts
1 hour ago, reedal said:
maybe you've said it before, but I can't remember. where do you get your copper from?
Metals Supermarket.  There may be a place to get it a bit cheaper, but Metals Supermarket lets you buy in literally any amount, small or large, and has copper for 40% of the cost of Amazon copper.  That 7" long piece of steel that we used for the alt bracket cost $9 since I didnt need any more than that.  Its nice for hobbyists.
Looks like there's one in Richmond (I see youre in VA), but also check for any metal supply place.
12 hours ago, 8ten8 said:
Yeah man, sick. Your bus layout with the 150's, great idea. Keep on with the pics...I'm taking notes
Thanks man, dont let the 150s fool you tho, we're running only 4/0 so there will be a bunch of 300A fuses in there... along with some capssss... :peepwall:
IG @walledsonic
  • 1 month later...
The Sonic took centerstage before the holidays, so we put the Jeep on hold temporarily.  Now for updates
Amp rack is coming along
Parts of the amp rack
M6 wood nuts for amp rack
Quick mockup
Preliminary testing with the IMSG says the port is tuned to 32Hz.  LOL, a bit low for a 4th order, but we're gonna break em in and then decide the final port length/tuning once everything is loosened up.
A lot more coming, we're trying to have Shadow ready for show season.
IG @walledsonic
Time to get this infrastructure under the hood in order.
Had to trim some plastic from the ECU block to fit the dual G34 battery tray
Got the 'back' bracket installed for the large case GM modular case alternator
Made a mistake on the dimensions, but that ok since we just used a countersunk bolt to make sure its flush on the face
Here you can see the overlap on the countersunk bolt in this pic
Making cuts on the front bracket
Here's a view of both brackets
Battery-alternator-engine ground... using 4/0
Theres some washers acting as spacers so that the lug will fit well
The alt is mounted facing backward, here's a view.  The belt was lined up perfect
IG @walledsonic
Tapping some copper for engine-bay-battery awesomeness
Working around this design.  Had an opportunity with a D3400 and a D3400R.  Really digging how minimal we can do the fuse block with reverse batteries.
New chassis-battery ground (4/0)
Routing
Countersinking
More routing
Bolts
Oh shit
Positive on top with fuses running down.  Negative/Ground on the lower terminal.  Reallly tight fit with 4/0
Keeping these cuts classy
Ran out of lugs for the Positive Alt-Battery run, so we threw some 1/0 in there for this week.  Updates to follow
IG @walledsonic
Holy Shit you weren't kidding! Nice f'ing job man!
  • 3 weeks later...
Updates.  More amp rack work
Some routing
Drilling and countersinking
Taping off the glue areas on the underside of the amp rack so we can paint the inside of the rack
Finished the clear panel for the 3.5K
The internal lead for the speaker output was sitting on the FETs.  Added a few zip ties so that the actual wire jacket isnt touching anything
Hauling ass now...  More painting this week and glue this weekend.  Once all that is dry we can install this thing and see how it sounds.
IG @walledsonic
