Lexus IS-F - Figs Engineering Rear Control Arms **UPDATE PAGE 4 - upgraded supports, Painted BLUE!
After dropping my car 2", i have noticed a little bit of inner tire wear. The ISF has no camber adjustment from the factory so there is really nothing you can do other then raise it back up.......and people who are BARELY LOWERED, if at all, still get inner tire wear issues. I have done some research and i think my next purchase is these.
http://www.figsprops.com/suspension.htm#arms
RACE MEGA - Standard Specs
TIG welded- interlocking tab construction.
Dimpled and lightened for maximum suspension response and stiffness.
FIGS FXM MOTO rod end standard 3-Piece Aurora AM12T Optional
Integral end fitting weldment, tube in box construction.
Upper triangle gusset standard.
Approx 4.6 lbs
Cost effective solution for tire wear
Slotted shock mount for leverage adjustment.
3-position sway bar endlink mounting options.
Stock Eccetric bolt for fine on-vehicle camber adjustments.(new eccentric bolt included on ISX50, IS-F and Gen3 GS applications)
Inner rod end adjusts for coarse camber offsets. Requires unmounting for adjustments.
next to the stock ones..
I am probably going to order them today. I am just trying to figure out if i am going to powder coat them, polish them, or leave them raw (with clear coat). I am leaning toward polished, but i am also looking at raw/clear since i sort of like that look. Figs is also working on something for the front and it should be ready soon! So i will be able to keep my drop and not hash tires every 6 months. :woot:
stay tuned i will post pics when they get here and of course the install!
:popcorn: :popcorn:
Follow my Tweet (Twitter)
I think blue powder coat would be secksy.*
*Biased because my favorite color is blue.
Realistically, I have to think polished would be the best looking, but they would show dirt.
Black would look good, and being that it looks like the rest of the undercarriage, it wouldn't stick out if its a little dirty.
I'm no fan of raw.
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
not a big fan of the raw. i just dont see it flowing well.of course it will probably never be seen but raw looks unfinished and unrefined to me. Everything the isf is not. Either way you look at it though it looks like it will do the trick.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 292 Guests (See full list)
