KOZ89 Posted March 4, 2012 Report Posted March 4, 2012 1/0 CCI ROYALE EXCELENE WELDING CABLE seen a couple people like yu-kong use this kind of wire for his install and i might as well pick some up myself, great deal, $2.48 a foot http://www.wireandsupply.com/category_s/57.htm Any thoughts on this? True wire gauge, etc build coming late April, early May build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/ 1997 Dodge Ram 1500 Slt Laramie Amplifier - AQ3500d.1 Sub - DC LVL 5 18" Highs - (2x) Selenium ST-350 Super Tweeters 8ohm Mids - Selenium 6" 200w midrange 6W4P (pair) Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch Wiring - XP Flex 25' Red, 25' Black Alternator - Mechman 270amp Battery - XS power D3100, 1- Yellow top front more to come...
vetkilr01 Posted March 4, 2012 Report Posted March 4, 2012 What I have usually found with welding wire is you need 2/0 to be comparable to 1/0 by say Kicker or a good quality ofc 1/0 gauge cable. But I have never used this brand before, and it doesn't say OFC copper ???
ChevyBoy95 Posted March 4, 2012 Report Posted March 4, 2012 It is true 1/0, but you have to remember, car audio wire is bigger than welding by a bit. but you can pay 4 dollars a foot for knu or kicker or pay 2.50 for 100% copper welding cable. Just remember, use lugs instead of ring terminals. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
michigancapri92 Posted March 4, 2012 Report Posted March 4, 2012 thats what im using and i think its awesome stuff !!!! you can solder and the sheathing does not melt no worries of engine bay melting it and the wire is very beefy love this stuff!!!1 Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
techforce Posted April 12, 2012 Report Posted April 12, 2012 Welding wire will carry a lot of current because the strands are more dense... a 20 ft run of the 0 gauge cable i use is rated to carry about 400-450 amps... the 2/0 gauge will carry 600-650 amps... ** NOTE TO ALL THE HATERS THAT GO AROUND BITCHING THAT I GIVE BAD ADVICE BECAUSE THEY DO NOT UNDERSTAND WHAT I DO ** I KNOW YOU ARE GOING TO SAY THAT THIS IS BULLSHIT, THAT WELDING CABLE CANNOT CARRY THAT MUCH CURRENT, WELL BELOW IS THE RATINGS FOR THE CABLE I USE @50 FEET, 20 FEET WOULD BE DRASTICALLY MORE, SO ENJOY AND CANNOT WAIT TO SEE WHAT IS WRONG WITH THIS CABLE I USE....
MIKE-2U Posted April 12, 2012 Report Posted April 12, 2012 Why NOT ring terminals ? 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
techforce Posted April 12, 2012 Report Posted April 12, 2012 OP, that welding cable you chose does not look that flexible... Plus it does not look like the amperage rating is that good.... the stuff I used in Yu-Kong is here and you can tie it in knots... https://weldingsuppl...OR:terms::PA#A2
Ninja_v1.0 Posted April 12, 2012 Report Posted April 12, 2012 i use 4/0 in da kar... pain in da ass to run but ti werks... just know those lugs are EXPENSIVE When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
rocking.that.eclipse Posted April 12, 2012 Report Posted April 12, 2012 i use 4/0 in da kar... pain in da ass to run but ti werks... just know those lugs are EXPENSIVE Why lugs instead of ring terminals?
uhoh_45 Posted April 12, 2012 Report Posted April 12, 2012 notice the difference R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
