What are you using? Inline Fuse Holders
AGU fuses (bottom picture) are only rated to 100 amps if I'm not mistaken. Anything bigger would have to ran on the ANL fuse (top picture)
2005 Chevy Colorado
Pioneer avic-x930bt
Alpine pdx-m12
Alpine pdx-f4
Focal is 165
Focal ic 165
Sundown SA 15 D4
Kicker 0/1 OFC power wire
Kicker 12 awg speaker wire
XS Power D2400
DC Power 270 H/O Alt
I just got a BlueSea ANL fuse holder (and fuses).
http://bluesea.com/c...productline/129
Expensive, but its so much better than most of the others.
I added some pics in my build log of how I used it.
Your second pic would be great if you need a waterproof option but as long as you're careful when washing the car, you shouldn't have an issue.
Wow that's a very nice high quality fuse holder.
That was the main thing I was worried about, depending how dirty the engine bay is, I spray it down annually. I would be doing the big 3 so I'll have 2 fuse holders in the bay that I would have to cover up somehow when I wash it.
Yeah I really like them after getting one.
My lesson's learned from looking at fuse blocks:
-Make sure that you aren't able to short out the fuse block terminals on metal (grounded) surfaces under your hood!
-Be careful on the cheap plastic covers. They tend to break easy and fall off....or not fit very well and not stay on.
-If you're careful you can wash under your hood just fine. 12V is low enough that you shouldn't have any shorting issues. You can always cover the fuseblock up with something while washing to divert most of the water if you're worried.
-Your electrical is just as important as your other audio equipment, invest now in something quality so you don't have to worry about it. The cheaper stuff will most likely give you issues in the future.
:drink40:
I wrap mine with electrical tape
Used to have a loud truck
Get an ANL style which is the 1st one... Not that one exactly but one like that because they are much nicer and have larger fuses available than the cylindrical ones
Team MaxRetribution
Si Vis Pacem Parabellum
There are a gajillion different makes/models...
here was a review done by a much respected cat on here...
shit looks great to me..
http://www.stevemead...w/#entry2189399
Again.. there are a lot out there to choose from...
EDIT - Want to say, ive never used any item in the link personaly. But do trust fully the cat that did the review.... Just tossing out the fact that there are a shit ton out there, that are above average....
Thank you!! I was searching the site and couldn't find a any decent fuses. I probably will try these, but will do some more seaching.
I was planning on going ANL especially when Knu kolossus 1/0 is rated at 300A. Both the ones above are actually ANL, the second ones left attatchment is turned a bit so it looks like AGU.
The second main thing I was worried about was durability. Especially since there is not one good spot to mount it in my car, it will just be laying. I didn't know how well the first one would hold up bouncing around, didn't want it to short if the cover werer to pop off.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
i use about 5 of style 1. the tops are secure as long as the wire is 1/0 or smaller and the ring terminals arent deformed (hammer crimping aka flat from smashing). i zip tie the plastic cover on for reassurance.
I use the huge KNUs with the triple mini-anl fuses.
They are huge though
http://www.knukonceptz.com/productDetail.cfm?prodID=KNI-11
and pricey.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 2804 Guests (See full list)
