Smoove's 1996 Chevy Ext cab C1500 Blowthrough RF, Fi, DD, SMD Meters 6th. updated pics start page 89
First a simple air intake upgrade : Intake Resonator Removal
Locate Resonator
Now go to Lowes and buy a 2" plumbers cap.
Remove Resonator and add plumbers CAP
Tranny swap update
No clutch master cylinder
No clutch pedal assembly
Pedal painting
Cutting hole for the master cylinder and clutch assembly bolts was a pain
Clutch assembly and master cylinader installed
White pedals installed
Chrome and black pedal pads are ordered and on the way. I will be putting a more detailed install of the clutch and brake assembly's on GMT400.com
Actual tranny swap should happen next weekend now that the pedals and master cylinder are in.
Locate Resonator
This is done to my truck ... better throttle response
I can't wait to see what kind of throttle response I get with the cap and the Vmax plenum spacer. The spacer is gonna go in right after the tranny swap.
Why are you changing to a standard ??
I saw 4.10's and got scared for your wallet...but then I saw the NV3500 swap thrown in there too. Sweet idea, sweet truck. Is she gonna get a repaint in the same colors?
I've been dreaming of swapping a 6.0 LQ9 bored out to a 414ci, with a pair of 62mm billet's and a built T56 into my truck. Just a dream, bank account isnt big enough yet :(
Tuned in for sure :)
I am doing a tranny swap because ever since the crate motor was installed I have gone through 4 4L60e's. So after talking to a buddy of mine, he talked talked me into doing the swap. He had the nv3500 sitting in his garage that he was gonna use on one of his projects. I picked up the tranny for only $320. The whole conversion will cost less another 4L60e or 65e. And the 4L80e is geared more for a work truck or 4x4 than a performance truck. I figure if the nv3500 takes a dump, then it's time to put in a T56 and 4:88 gears.
I put in the 4:10's years ago cause I wanted more off the line torque. The open diff 3:42's bugged me because I prefer posi in a truck.
My friend dropped the 6.0 in his rock krawler. http://beastfab.com/coppermine/index.php'>http://beastfab.com/coppermine/index.php http://beastfab.com/
I am also thinking about doing a vortec marine intake since the one that comes in the truck has limited injectors you cant upgrade.
I wanna keep the truck blue with some white pin striping when it gets repainted. The interior is gonna be blue, white and light grey.
