Interesting....
I guess that could be another thing to test in the mix. Silver vs 50/50 solder
didnt know that about solder, always that it provided the best connection.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Well, the way I see it. That solder, even though has less conductivity than copper, does not a single thing negative to your conducitivity. Because without it, everything is still going through your ring terminal regardless. Then when you use solder, it just adds a little bit more surface area for it to travel through. Correct me if I am wrong though.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Most people do. But what happens is... the solder works it's way in between everything, because that's what it does, and basically insulates it. It's fine for smaller connections, mind you. But I wouldn't use it on something where current transfer is paramount,
It don't get no better than this, cuz...
514CBFE0-7015-40B3-99C7-6049648AA3C1-798
I've always soldered my connections...TFade actually brings up a point I never spent too much thought on. Now I'm curious
  • 4 weeks later...
