more of the things i have figured out somewhat correct me if im wrong
sopeonarope89
my setup 2 hifonics 8'' speakers 2 jl audio 10'' subwoofers and 1 15 kicker comp cvr subwoofer
links of things im using
http://www.sonicelectronix.com/item_68786_Hifonics-HF8SQ-i4.html
the jl audio subs i have are the 10w3v2 but these are the same just about
http://www.sonicelectronix.com/item_69578_JL-Audio-10W1v3-2.html
now the 15 i have is soo old u cant find them ... but heres one that is kinda just like it ... also the sub has more wattage rms mines a 4 ohm but the one ima link is 2 ohm and mine handles 1000w max and the one ima link handles 500w max .
http://www.sonicelectronix.com/item_43590_Kicker-C152-10C152.html
the first link is exact the second one is close and the third one has same hz range the links to what i have . since i have old subs
my amps im using on this system ...
http://www.sonicelectronix.com/item_12018_Alpine-MRP-M500.html this amp has almost the same specs ... just without the subsonic filter
and i have a sony xplod 600w 4 channel amp .... they dont sell them anymore on sonic electronics soo ....
and i have a dual
http://www.sonicelectronix.com/item_24120_Dual-XDMA6355.html
i tuned it for hours on a eq preamp i had that has 7 eq on each output and their are 3 outputs each for front rear and sub
http://www.sonicelectronix.com/item_44120_Boss-EQ600.html is the preamp i talk about
and my issue atm with it is the bass ... i have it tuned tocatch what i want .... but even tho i have the 60 hz range turned all the way down it is still too loud
Why do you have so many different sized sub woofers? What purpose do you "think" it serves?
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
What he said.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
I'm not even sure what's going on right now and i haven't even sniffed booze today
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I don't understand what's being said our asked buy I do have advice.
1 forget about max rating of anything, amps subs speakers it's all bs. Only rms matter.
2 make a goal and complete the goal
3 read and learn on the forum.
Oh and Sony and dual are garbage, take the max rating and divide it by 2-3 maybe even 4 to get the real rating.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
What I got from the thread...n
Bass is too loud. No advice can be given. My brain can't understand the version of English being used. Rosetta Stone doesn't have anything to help in this situation. I'll attempt:
Your louds are ima louder than your needs. Please post a second threads about maybe possibly also different equipment for us to help with you're situations here at hand.
  • Who's Online   2 Members, 0 Anonymous, 985 Guests (See full list)
