poorfish88 Posted July 9, 2014 Report Posted July 9, 2014 Yellow top was a bad pick, but at least it's a AGM batt. Hope you have good luck with it there quality has gone way down. The big 3 is a must upgrade, when you start to have voltage drop. i was told by numerous people that the big 3 is a waste if your system is under 1000 watts... my brother has 3000 watts running on 2 regular car batteries and no big 3 and has no voltage drop...i just think the battery was too old in my car. Also he has an old 97 wrangler and i have an 06 sonata. I gave you great advice walk away from it if you want. Return the yellow top for a better AGM and do the Big 3. What 3000 watt amp is your brother running, cause the massive 90 watt stock alt on a Wrangler is going to drop at least to battery voltage. There isnt any of those batteries that work with my car. I looked it up on the XS site and spoke with a rep and they said they dont have any options that they believe will work with my car. Many people on here have told me XS before but there nobody online I can use as a reference for the size needed. Since im stuck with the yellowtop I will be installing the big 3 once I get the battery next week. Ive called a couple auto shops around here and they all said they either use Optimas for customers or Kinetic batteries. (My brother has the amp for subs running to its own battery. His amp lights flicker when bass hits but he is only showing a .5 voltage drop. Dont know if thats alot but we read it with the multimeter last night. His system is actually 2000 watts- mistyped it. ) What group size batt did you buy? The 124r group size isn't made by Optima either as far as I know. Anyways I hope it works out for u cause some yellow tops are tough as hell.
Daniel Francis Sheppard Posted July 9, 2014 Author Report Posted July 9, 2014 Yellow top was a bad pick, but at least it's a AGM batt. Hope you have good luck with it there quality has gone way down. The big 3 is a must upgrade, when you start to have voltage drop. i was told by numerous people that the big 3 is a waste if your system is under 1000 watts... my brother has 3000 watts running on 2 regular car batteries and no big 3 and has no voltage drop...i just think the battery was too old in my car. Also he has an old 97 wrangler and i have an 06 sonata. I gave you great advice walk away from it if you want. Return the yellow top for a better AGM and do the Big 3. What 3000 watt amp is your brother running, cause the massive 90 watt stock alt on a Wrangler is going to drop at least to battery voltage. There isnt any of those batteries that work with my car. I looked it up on the XS site and spoke with a rep and they said they dont have any options that they believe will work with my car. Many people on here have told me XS before but there nobody online I can use as a reference for the size needed. Since im stuck with the yellowtop I will be installing the big 3 once I get the battery next week. Ive called a couple auto shops around here and they all said they either use Optimas for customers or Kinetic batteries. (My brother has the amp for subs running to its own battery. His amp lights flicker when bass hits but he is only showing a .5 voltage drop. Dont know if thats alot but we read it with the multimeter last night. His system is actually 2000 watts- mistyped it. ) What group size batt did you buy? The 124r group size isn't made by Optima either as far as I know. Anyways I hope it works out for u cause some yellow tops are tough as hell. the yellowtop for mine is D34/78. Im apart of a Sonata forum site and a couple of people have experimented and found that this works with our type of sonata. That is what I meant when I said I looked for an online reference as well.
Broke_Audio_Addict Posted July 10, 2014 Report Posted July 10, 2014 So if it's a group 34 an xs d3400 should fit too. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Miguels Posted July 10, 2014 Report Posted July 10, 2014 D3400 is a group 34 my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Daniel Francis Sheppard Posted July 11, 2014 Author Report Posted July 11, 2014 Put in the yellowtop today... no drop at all really.. read 13.6 and when bass hits it only drops to 13.4. Old battery dropped to 12.2
poorfish88 Posted July 11, 2014 Report Posted July 11, 2014 If you were dropping before then you should be dropping to battery voltage at least. 13's is still alt voltages, test the batt with the car off and see what I mean. The batt should be around 12.5-7ish with the car off. Or maybe you had a loose battery conncetion.
Guest Posted July 11, 2014 Report Posted July 11, 2014 no drop until a cell dies. then your car wont start. edit: old battery was probably old as shit, hence the voltage drop.
Swordlordboy1234 Posted July 11, 2014 Report Posted July 11, 2014 No drop he says. Lol... More lulz to be had with a stubborn newbie who has a brother with a magic electrical system. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Bump4life Posted July 11, 2014 Report Posted July 11, 2014 if his old battery was bad i could see this being the case? i dont know what kinda power or alternator he runs though. if he is drawing more power than his alt then holding above battery resting is impossible Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Sutliff Posted July 12, 2014 Report Posted July 12, 2014 upgrade front bat to agm & if you want too get another small for the back OP: This is what I did ... I had same problem, ... It is all in my Build Log below. Zeke '14 2003 Chevy Monte Carlo SS Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/ Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build Pioneer FH-P8000BT Infinity Kappa Perfect 6.1 Fi IB3 (Two 12", 2-ohm SVC) RF T400-2 & T500-1bdCP MechMan S Series 240A XS Power D3400 & D975
