DC Sound Lab
Im feeling a little sceptical but the CJ guy says he can get me a frame, and recone hmmm
Good luck getting enough spider to allow any excursion. I know you look to have changed your mind a bit which is a good thing.
Just a quick FYI, the Level 6 coil is 3.5" in diameter. It doesn't leave you with much meat on a typical 9.25" spider.
The new 6 spoke basket that Fi/Crossfire came out with will accommodate a 10" spider. Look for the Crossfire XSv2 12" in a blowthrough in the near future.
Edited by CleanSierra
Incorrect. The Level 6 uses a 4" coil. To be built it would use a TC frame and 10" spider. Same spiders that are used on the 15" and 18" versions.
I am not biased in any way. I nether like nor dislike DC. My question is similar to above. If it worked wouldn't DC be selling a level 6 12?
Still learning but have started gathering.
Oops, I was thinking of the Level 5.
Can I see a tape measure on the Ti basket to show it's truly a 10" spider? My Crossfire C7 12s utilize the 4 spoke Ti basket and I've been told they are only 9.25" spiders. I know there is a reason that Roger won't put the big XS motor on my basket and that's because he said there isn't enough spider, hence the reason they tooled the new 6 spoke Ti basket with TRUE 10" landings.
Have fun with a Level 6 12, as far as I know it's only been done once and the results were less than stellar.
It's been done before and like 88 said, the results weren't what you'd expect. If you want a sweet 12 that will work mechanically try using a sp4 12. I have a feeling you might be in for a headache of you make those 12 inch level 6s
Level 6 is a turd anyway,...imho.
cut its legs out from it, meh.
So you want the level 6 motor (that isnt all that) on a smaller basket, smaller coil, smaller spider?
sounds like a win.
it wouldnt be a smaller coil or smaller spider but there is a reason lv6 12s arent made.... they dont fucking work
  • Who's Online   0 Members, 0 Anonymous, 431 Guests (See full list)
