Running welding wire 1/0
KOZ89
1/0 CCI ROYALE EXCELENE WELDING CABLE
seen a couple people like yu-kong use this kind of wire for his install and i might as well pick some up myself, great deal, $2.48 a foot
http://www.wireandsupply.com/category_s/57.htm
Any thoughts on this? True wire gauge, etc
build coming late April, early May
build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/
1997 Dodge Ram 1500 Slt Laramie
Amplifier - AQ3500d.1
Sub - DC LVL 5 18"
Highs - (2x) Selenium ST-350 Super Tweeters 8ohm
Mids - Selenium 6" 200w midrange 6W4P (pair)
Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch
Wiring - XP Flex 25' Red, 25' Black
Alternator - Mechman 270amp
Battery - XS power D3100, 1- Yellow top front
more to come...
What I have usually found with welding wire is you need 2/0 to be comparable to 1/0 by say Kicker or a good quality ofc 1/0 gauge cable. But I have never used this brand before, and it doesn't say OFC copper ???
It is true 1/0, but you have to remember, car audio wire is bigger than welding by a bit. but you can pay 4 dollars a foot for knu or kicker or pay 2.50 for 100% copper welding cable. Just remember, use lugs instead of ring terminals.
thats what im using and i think its awesome stuff !!!! you can solder and the sheathing does not melt no worries of engine bay melting it and the wire is very beefy love this stuff!!!1
  • 1 month later...
Welding wire will carry a lot of current because the strands are more dense... a 20 ft run of the 0 gauge cable i use is rated to carry about 400-450 amps... the 2/0 gauge will carry 600-650 amps...
** NOTE TO ALL THE HATERS THAT GO AROUND BITCHING THAT I GIVE BAD ADVICE BECAUSE THEY DO NOT UNDERSTAND WHAT I DO **
I KNOW YOU ARE GOING TO SAY THAT THIS IS BULLSHIT, THAT WELDING CABLE CANNOT CARRY THAT MUCH CURRENT, WELL BELOW IS THE RATINGS FOR THE CABLE I USE @50 FEET, 20 FEET WOULD BE DRASTICALLY MORE, SO ENJOY AND CANNOT WAIT TO SEE WHAT IS WRONG WITH THIS CABLE I USE....
notice the difference
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   1 Member, 0 Anonymous, 1281 Guests (See full list)
