LEDs are all Plasmaglow
Here is the underbody kit iirc http://www.plasmaglow.com/2-1-million-color-led-under-car-kit/
Here are the interior lights he bought ( 2kits where bought for 20 little led lightbars) http://www.plasmaglow.com/led-illuminators/
Also if you buy these, you need to buy a seperate brain if you buy the rgb color changing lights which are what we are using or else you wont be able to change colors.
http://www.plasmaglow.com/colorstrike-led-controller/
However by buying a extension cable for the underbody kit, and snipping a plug off I was able to get most colors from the brain being used in the 2.1million underbody kit.
Those prices are MSRP, you can find the kits a little bit cheaper. I think I found the little interior ones for $65 per set.
Good shit as usual Brian.
Now it's time for a new build of your own. What about 10+ subs this time around?
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
you need a trunk trim piece to cover up that damplifier
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I dont usually give good work.. but when i do....
:good:
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
That video answered a lot of the questions that I had. how hard do you think it would be to match the LED to the music somehow. I thing that would be really cool especially in the sub box. Also how do you thing the LEDs under the car are going to hold up during the WIS. winter? or does he not drive it then? One more then I'm done, later in the video i looked like the rear lights have been blacked out, have they?
1996 Ford Explorer Eddie Bauer V8 AWD
So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
That would be easy if chargers came with them. ;)
going to be fiberglassing a cover for it. :P
:good:
:ninja:
:good:
Honestly, every underbody kit that is able to be music activated and uses a microphone to sense the beat is wack. you can turn the sensitivity down on the mic all the way, and still make the kit light up constantly just with the stock stereo, let alone a high powered system.
I think there are only a few kits that use a RCA input for the music mode and would be something you would need if you wanted the music feature. I spouse you could mod the brain on a kit like this and unsolder the onboard mic, and solder a rca input into for a low level input and than adjust the mic sensitivity like a gain on a amp.
As for his underbody kit, I think its about 2.5 years old. It shows signs of wear and tear, I think the front tube has 1 color that does not work on the far end, and a side tube has a crack plastic tube with a hole in it, which allows moisture and water to get inside it. The tube still works flawless. Id imaging it was from an ice chunk in the road, or possibly a rock that hit the tube.
I tried talking him into the Iceled UFO kit but that was a no go due to it being expensive. Keep in mind, these are a rather cheap LED kit, with a few more options than the StreetGlows leds (which i think are generic).
At the end of the day, light output is nothing like a true quality streetglow gold series neon kits
nice trunk. what kind of numbers does she put up?
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
Nice install, on an odd side note if you ever get a tooth ache again, goto a CVS/Walgreens/Albertsons etc and look for in the dental isle a product called "First Aid" it's 100% pure clove extract and it WILL kill any tooth pain in a matter of seconds, and it's much better than that orajel junk.
PS - I envy your workshop, me with only a garage :(
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
