White Lightning Posted April 17, 2018 Report Posted April 17, 2018 3 minutes ago, robsimon799 said: I'm asking how so? I'm want sq and spa at diffriont times. sorry for the spelling. Simple answer really. It’s always better to research, test, tune, and do more with less. Take a look at my 2 build logs on my signature. One of them is a Ford F-150 Super Crew. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
CstrokerV Posted April 17, 2018 Report Posted April 17, 2018 None of your gear other then the morels can even start being called sq plus way to much gear my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
robsimon799 Posted April 17, 2018 Author Report Posted April 17, 2018 the speakers is good anuff im not trying to win anything. but i know my bmw e46 m3 will sound better with morels highs and mids
Triticum Agricolam Posted April 17, 2018 Report Posted April 17, 2018 If you haven't seen it yet, the MiniDSP C-DSP 8x12 gives you eight channels of input and twelve channels of output. It doesn't do everything you want to do, but it does a lot: https://www.minidsp.com/products/car-audio-dsp/c-dsp-8x12 "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
WalledSonic Posted April 17, 2018 Report Posted April 17, 2018 15 hours ago, robsimon799 said: The fuel system the be a 2 stage 91 OCT main injector to sec. injectors with 100% methanol with 16 injectors total Engine MMR 400 CU GEN X ,10:1 comp, Turbo cam, DOHC V8 Engine Nelson Racing 72mm Twin Turbos Custom dual inlet single out air to air intercooler with fans Intercooler piping Oil cooler with fan Oil catch can with air filters Coolant res Top mount turbo manifolds Electric water pump AN fittings on rad and engine and everything under the hood Electric rad fan and electric water pump Frame IFS IRS AWD box frame Custom control arms for rear Custom A arms for front Custom knuckles Rack and pinion steering Suspension Airlift slammer shocks bags or Airlift bags and JRZ shocks 2 Airlift air comp. 480c airlift p/h controller 1 ton ball joints Spidertrax hubs 5/8"-18 studs on a 6 on 5-1/2" bolt circle and 40 splined axle shafts front and rear 2 Wilwood Brake Kits No: 140-8992-D for front and rear Savini XLT SV25-S Wheels: Custom chrome same from front to rear 26 x 10 or 26 x 12.5 or 26 X the widest max pirelli P Zero all session Drivetrain TCI 6 speed transmission and outlaw shifter SCS transfer case RCV custom CV Axles front and rear Two Currie F9 9” diff housings, flanges, bearing and seals Two Nitro drop outs Two Auburn Gear ECTED MAX diffs OR front and rear 8.8” ford Sport Trac Andrenan AWD diffs housings with ected max diffs Fuel 2 Radium fuel cells and surge tanks -10 black braded fuel feed hose Exhaust 2 HKS ti burn tip mufflers 75mm inlet 3” exhaust pipe two 3” vibrant cats v band 3” Lights IPCW LED black housing Tail Lights Spec-D - Black/Smoke Dual Halo Projector LED Headlights modified housings XK Glow smart phone controlled under lighting and interior lighting 2 round grill lights 7” dia. Body Sarona front clip FD-010-FB Sarona side surts FD-006-SS Sarona rear clip FD-007-RB Sarona front fenders FD-004-FD Sarona air ram hood FD-006-HD ARE LS2 Tonneau Cover BMW flossmann gt2/3 rear spoiler with red led brake light Ford f150 sun roof Mesh matt black grill Black Truck with Blue accents Audio E3iO Computers fully loaded car pc E3iO 10” screen Alpine pxa-h800 Alpine rux-c800 Custom Switchable stereo to stereo/mono units 7 channels 2 Crescendo C2000.4 amps 5 Crescendo SYMPHONY S550/2 3 crescendo s800/4 2 Orion HCCA 3000.4 for the 2ohm 8” subwoofers in kicks and back of cab made out of MDF and fiberglass 2 Ground Zero 35000 Watt RMS Amps low pass 80HZ for 18” subs 4 Crescendo PWX 10" Pro audio 500rms 4 ohm 8 PWX 6.5" Pro Audio 250rms 4 ohm 4 PWX 8" Pro Audio 300rms 4 ohm 7 Crescendo FT1 Super tweeters 80rms 7 UN-1 ULTRA NEO COMPACT COMPRESSION HORN 7 Morel ULTIMO TITANIUM 8” 2 ohm Subwoofers 4 Ground Zero SPL Extreme 18” subwoofers audio pipe crossovers Wiring and electrical Push button start with switches for ign. ACC. Fuel pumps aux lighting and FAST XFI 2.0 FAST XFI EDASH M&W PRO DRAG 8 CDI Weapon X XCOP EFX Direct Fire Ignition Coil Add on fuse box for lighting 8 gauge input Mechman E Series 6 phase 370 amp alternator for 5.0 Coyote 8 XS Power lithium batteries XS30K sky high car audio OFC 2/0 gauge blue power and ground cable sky high car audio OFC 4 gauge blue power and ground cable sky high car audio blue OFC speaker wire 16awg for 6 ½ mids and tweeter horns / 14awg for the 10” mids and 8” mids/ 10awg for the 8” subs / 8awg for the 18” subs. 9 SKY HIGH CAR AUDIO 2/0 ANL FUSE HOLDER - SET SCREW. 4 sets SKY HIGH CAR AUDIO DUAL 2/0 TO 1/0 AMP INPUTS GZ 35000.1 amp 2 sets SKY HIGH CAR AUDIO 2/0 TO 1/0 Amp inputs for HCCA 3000.4 amp. Interior Corbeau black leather Heated CR1 seats blue face gauges for dash cluster blue led for gauges and dash and window power switches clear gauge needles Phantom 2 BOOST/VACUUM, 30 IN HG/45 PSI gauge And all other autometer phantom 2 gauges we need on 3 pod a piller and dash. Custom mdf and carbon fiber Center console 18” subs sub box ported @ 20HZ sub box in bed of truck with bed front cut out and back of cab cut out. So whos building this? Im curious bc its nice to have dreams, but executing the build youve listed would be daunting, lengthy, and crazy expensive. Youre opening a shop and blowing $100k+ on a vehicle at the same time? Hmm. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
robsimon799 Posted April 17, 2018 Author Report Posted April 17, 2018 i have the money to blow. and i have the correct help to build this beast. we are starting with a fully stock F150. and im also doing a e46 m3 turbo nitrous coupe
Broke_Audio_Addict Posted April 17, 2018 Report Posted April 17, 2018 52 minutes ago, robsimon799 said: i have the money to blow. and i have the correct help to build this beast. we are starting with a fully stock F150. and im also doing a e46 m3 turbo nitrous coupe Let me hold a dollar. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Phaeton Posted April 17, 2018 Report Posted April 17, 2018 Whens the build log starting my dude? 1997 subaru legacy outback Four 15's in a almost wall Rockford Fosgate t2500-1bdcp Rockford Fosgate T400-4 on tweets Rockford Fosgate T400-4 on highs Rockford Fosgate T400-2 on midrange Rockford Fosgate T400-2 on midbass Optima Yellow top batteries 270A Singer alt (working on a bracket for a second) Lots of Second Skin
White Lightning Posted April 17, 2018 Report Posted April 17, 2018 That will make a cool demo rides if you pull it off. If the shop you open up carries everything you install in your rides. Also the fact you will be making a billboard for your shop so make your install practices count. Just saying Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
